Aller au contenu principal
Introduction
This guide will go over where to locate and replace the rear cooling fan. You will need to reference the Removing Samsung ML2510 Back Panel repair guide to complete this one.
Pièces
Aucune pièce spécifiée.
  1. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
    • Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
  2. Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2  screws on the back of the printer.
    • Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2 screws on the back of the printer.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. Gently lift the top panel while simultaneously pulling off the back panel. Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot. Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  5. Once the fan is detached, unplug the fan from the circuit board. Slide the fan's wiring through the anchored slit.
    • Once the fan is detached, unplug the fan from the circuit board.
    • Slide the fan's wiring through the anchored slit.
  6. With the new fan, thread the wiring through the old fan's slit.
    • With the new fan, thread the wiring through the old fan's slit.
    • Reconnect the fan by plugging it back into the circuit board.
    • Reattach the back panel following these instructions in reverse order.
Ligne d'arrivée
bbaustin
Membre depuis le 12/10/2011
199 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 17-18, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 membres
6 tutoriels rédigés
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
Bax Bagatelli - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 2,873
