Introduction
This guide will require you to disassemble the back and side panel of the printer. You will need to refer to the Retrait du panneau arrière du Samsung ML2510 guide in order to complete the task.
Ce dont vous avez besoin
Remove the top hinged panel by taking out the pins at the bottom of this panel.
Locate the holes on the panel that are attached to the main body.
Remove the front panel by gently moving the holes from the pegs one by one.
2 autres ont terminé cette réparation.
