Aller au contenu principal
Samsung NP R580 JBB2 Cooling Fan Replacement
Ce dont vous avez besoin
  1. Samsung NP R580 JBB2 Cooling Fan Replacement, Cooling Fan: étape 1, image 1 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement, Cooling Fan: étape 1, image 2 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement, Cooling Fan: étape 1, image 3 de 3
    • Remove the battery by sliding the battery release latches laterally outward into the unlatched position.
    • Slide the battery upwards out of the battery housing.
    • Remove the SD card placeholder.
  2. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 2, image 1 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 2, image 2 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 2, image 3 de 3
    • Remove the 9mm Phillips head screw labeled "ODD."
    • Slide the DVD drive out of the body.
    • Remove the two 3mm Phillips head housing screws.
  3. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 3, image 1 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 3, image 2 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 3, image 3 de 3
    • Remove the two 9mm Phillips head screws on the back plate labeled "memory."
    • Remove the back plate labeled "memory."
    • Disconnect the two gray connectors.
  4. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 4, image 1 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 4, image 2 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 4, image 3 de 3
    • Remove the two 5mm Phillips head screws on the back plate labeled "HDD."
    • Remove the back plate to the hard drive by pulling downward and lifting away.
    • Pull laterally to the left on the black tab until it releases its connection and is able to be lifted free.
  5. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 5, image 1 de 1
    • Remove the two 7mm Phillips head keyboard screws on the back plate labeled "KBD."
  6. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 6, image 1 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 6, image 2 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 6, image 3 de 3
    • Open the computer and locate the three keyboard release tabs. Once located, use a flat metal device to pry the tabs open.
    • Lift the keyboard away to discover its ribbon connector beneath.
    • Lift the black portion of the connector to release the ribbon and set the keyboard aside.
  7. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 7, image 1 de 2 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 7, image 2 de 2
    • Disconnect the mouse pad ribbon connector by pulling the grey connector downwards toward the mouse-pad, freeing the ribbon.
    • Disconnect speaker wires by pulling it upwards toward the laptop screen.
  8. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 8, image 1 de 1
    • Remove the sixteen 9mm Phillips head housing screws on the back plate.
  9. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 9, image 1 de 1
    • Pry off the keyboard housing plate with the metal spudger and set aside.
  10. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 10, image 1 de 2 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 10, image 2 de 2
    • Disconnect the white USB drive plug by pulling outwards using a nylon spudger.
    • Disconnect the blue DVD player ribbon tab by pulling the blue tab outwards laterally away from the mother board using a nylon spudger.
    • Disconnect the screen connection wire by pulling it towards the screen using a nylon spudger.
  11. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 11, image 1 de 1
    • Remove the three 5mm Phillips head screws on the motherboard and the one 5mm Phillips head screw on the fan.
    • All screws have white arrows pointing towards them.
  12. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 12, image 1 de 2 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 12, image 2 de 2
    • Work the motherboard out of the housing by lifting upwards.
    • Disconnect the fan's cord from the motherboard by pulling upwards on it.
  13. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 13, image 1 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 13, image 2 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 13, image 3 de 3
    • Loosen the four self-retaining screws located on the copper cooling bar.
    • Lift and remove the fan.
  14. Samsung NP R580 JBB2 Cooling Fan Replacement: étape 14, image 1 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 14, image 2 de 3 Samsung NP R580 JBB2 Cooling Fan Replacement: étape 14, image 3 de 3
    • Remove the three 3mm Phillips screws on the fan housing.
    • Peel the tape off of the fan housing.
    • Remove the fan from the cooling hardware.
13 autres ont terminé cette réparation.
Brian Adamson
Membre depuis le 10/10/16
532 Réputation
3 tutoriels rédigés
Équipe
Texas Tech, Team 6-2, Bennett Fall 2016 Membre de l'équipe Texas Tech, Team 6-2, Bennett Fall 2016
TTU-BENNETT-F16S6G2
4 membres
3 tutoriels rédigés
2 commentaires
Hi where can I get a fan for my R580 Samsung laptop. Please help i have tried to find one but no luck!!! I stay in South Africa. Thanks
Deon Kotze - Réponse
Is it the same with its bigger brother, the NP R780?
Andreas M - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 9
30 derniers jours : 34
Total : 3,954
