Aller au contenu principal
Samsung NP-130-JA01US Keyboard Replacement
Ce dont vous avez besoin
  1. Samsung NP-130-JA01US Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
  2. Samsung NP-130-JA01US Keyboard Replacement: étape 2, image 1 de 2 Samsung NP-130-JA01US Keyboard Replacement: étape 2, image 2 de 2
    • Slide the left and right slider buttons fully away from each other.
  3. Samsung NP-130-JA01US Keyboard Replacement: étape 3, image 1 de 1
    • Pull the battery out of the computer.
  4. Samsung NP-130-JA01US Keyboard Replacement, Keyboard: étape 4, image 1 de 2 Samsung NP-130-JA01US Keyboard Replacement, Keyboard: étape 4, image 2 de 2
    • Using a Phillips 1 screwdriver carefully remove all 12 screws of the back cover.
    • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    • Do not force the screwdriver as you might damage the screws.
  5. Samsung NP-130-JA01US Keyboard Replacement: étape 5, image 1 de 3 Samsung NP-130-JA01US Keyboard Replacement: étape 5, image 2 de 3 Samsung NP-130-JA01US Keyboard Replacement: étape 5, image 3 de 3
    • Flip the computer and open the front cover so that the screen is looking at you.
    • Using a Metal Spudger and your dominant hand, carefully separate the keyboard from the computer frame.
    • Do not force the keyboard out, it should come out easily with the help of the Metal Spudger
  6. Samsung NP-130-JA01US Keyboard Replacement: étape 6, image 1 de 3 Samsung NP-130-JA01US Keyboard Replacement: étape 6, image 2 de 3 Samsung NP-130-JA01US Keyboard Replacement: étape 6, image 3 de 3
    • Flip the keyboard over.
    • Notice the lock mechanism (marked in red) that holds the cables to the computer.
    • With your fingers, flip the mechanism over before pulling the cables out.
    • Second picture shows the unlocked position.
    • Carefully pull the cables out of the computer.
Alejandro Guerra Piol
Membre depuis le 09/12/16
319 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 9-6, Lacy Fall 2016 Membre de l'équipe USF Tampa, Team 9-6, Lacy Fall 2016
USFT-LACY-F16S9G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 330
