Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide will provide instructions on how to fully replace the battery on a Samsung N145 laptop. You will be given steps on how to detach the current battery of your device and attach a new one. You will want to perform this replacement if the battery of your device does not charge when it's plugged in or it does not hold a charge.
  1. Before starting the replacement, turn off the device and disconnect all cords from the computer.
    • Before starting the replacement, turn off the device and disconnect all cords from the computer.
    • Close the device and lay it face down.
  2. OUVRIR TOUS LES ONGLETS
    Kits de mise à jour de RAM pour Mac
    Voir les kits
    Assez de RAM
    pour ouvrir tous les onglets
    Voir les kits
  3. Locate both the battery locking latches on the lower right and left sides of the battery. Slide both locking latches outwards simultaneously to unlock the battery. While holding the locking latches in the outward position, pull the battery off and set it off to the side.
    • Locate both the battery locking latches on the lower right and left sides of the battery.
    • Slide both locking latches outwards simultaneously to unlock the battery.
    • While holding the locking latches in the outward position, pull the battery off and set it off to the side.
    • Release the locking latches after completely removing the battery.
Laura Denali Harbinson
Membre depuis le 18/01/2017
404 Réputation
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 424
