Aller au contenu principal
Samsung NP-NC10-KA02US RAM Replacement
Ce dont vous avez besoin
  1. Samsung NP-NC10-KA02US RAM Replacement, Battery: étape 1, image 1 de 2 Samsung NP-NC10-KA02US RAM Replacement, Battery: étape 1, image 2 de 2
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US RAM Replacement: étape 2, image 1 de 1
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US RAM Replacement: étape 3, image 1 de 1
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US RAM Replacement, Back Plate: étape 4, image 1 de 1
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US RAM Replacement: étape 5, image 1 de 1
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US RAM Replacement: étape 6, image 1 de 2 Samsung NP-NC10-KA02US RAM Replacement: étape 6, image 2 de 2
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
  7. Samsung NP-NC10-KA02US RAM Replacement, Fan: étape 7, image 1 de 2 Samsung NP-NC10-KA02US RAM Replacement, Fan: étape 7, image 2 de 2
    • Remove the three screws holding the fan using a 3.9mm screwdriver.
    • All three screws need to be removed in order to continue on to next step.
  8. Samsung NP-NC10-KA02US RAM Replacement: étape 8, image 1 de 1
    • Unplug the wires connected to the fan using a plastic opening tool.
  9. Samsung NP-NC10-KA02US RAM Replacement: étape 9, image 1 de 1
    • You are now able to carefully detach the fan from the base.
  10. Samsung NP-NC10-KA02US RAM Replacement, RAM: étape 10, image 1 de 1
    • After detaching the fan, you are now able to remove the RAM by extending the two side bars out
    • During this process, the computer needs to be shut off. Other components could be damaged and the computer would not be able to recognize the RAM properly.
  11. Samsung NP-NC10-KA02US RAM Replacement: étape 11, image 1 de 2 Samsung NP-NC10-KA02US RAM Replacement: étape 11, image 2 de 2
    • With the bars extended, you are now able to slide the RAM off the base.
3 autres ont terminé cette réparation.
JHOAN USECHE
Membre depuis le 10/03/16
372 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Sullivan Fall 2016 Membre de l'équipe USF Tampa, Team 1-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 381
