Aller au contenu principal
Samsung NP-NC10-KA02US WLAN Card Replacement
Ce dont vous avez besoin
  1. Samsung NP-NC10-KA02US WLAN Card Replacement, Battery: étape 1, image 1 de 2 Samsung NP-NC10-KA02US WLAN Card Replacement, Battery: étape 1, image 2 de 2
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US WLAN Card Replacement: étape 2, image 1 de 1
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US WLAN Card Replacement: étape 3, image 1 de 1
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US WLAN Card Replacement, Back Plate: étape 4, image 1 de 1
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US WLAN Card Replacement: étape 5, image 1 de 1
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US WLAN Card Replacement: étape 6, image 1 de 2 Samsung NP-NC10-KA02US WLAN Card Replacement: étape 6, image 2 de 2
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
  7. Samsung NP-NC10-KA02US WLAN Card Replacement, WLAN Card: étape 7, image 1 de 1
    • Using a 3.93mm Phillips screwdriver remove the screw attaching the WLAN card.
  8. Samsung NP-NC10-KA02US WLAN Card Replacement: étape 8, image 1 de 1
    • Gently lift the WLAN card.
  9. Samsung NP-NC10-KA02US WLAN Card Replacement: étape 9, image 1 de 2 Samsung NP-NC10-KA02US WLAN Card Replacement: étape 9, image 2 de 2
    • Gently using a plastic opening tool, remove the two latches attached to the WLAN card in the netbook.
    • Your WLAN card is now removed.
2 autres ont terminé cette réparation.
Abigail Nicholas
Membre depuis le 10/05/16
346 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Sullivan Fall 2016 Membre de l'équipe USF Tampa, Team 1-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 476
