Introduction
If you want to replace your hard drive for problems such as being unable to access files, this guide walks you through lifting the cover and removing the hard drive. The steps should be easy to follow. Just make sure to wear an anti-static wristband to avoid shocking the motherboard.
Ce dont vous avez besoin
Flip the laptop.
Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
