Aller au contenu principal
Samsung NP-R540-JA09US Front Panel Replacement
Ce dont vous avez besoin
  1. Samsung NP-R540-JA09US Front Panel Replacement, Battery: étape 1, image 1 de 1
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
  2. Samsung NP-R540-JA09US Front Panel Replacement: étape 2, image 1 de 1
    • Pull the two latches outward.
  3. Samsung NP-R540-JA09US Front Panel Replacement: étape 3, image 1 de 2 Samsung NP-R540-JA09US Front Panel Replacement: étape 3, image 2 de 2
    • Slide the battery out of the laptop.
  4. Samsung NP-R540-JA09US Front Panel Replacement, Optical Drive: étape 4, image 1 de 1
    • Remove securing screw with the PH0 head.
  5. Samsung NP-R540-JA09US Front Panel Replacement: étape 5, image 1 de 1
    • Slide the optical drive out and remove it from the device.
  6. Samsung NP-R540-JA09US Front Panel Replacement, Keyboard: étape 6, image 1 de 1
    • Remove the two Phillips #0 screws labeled KBD.
    • There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
    • Make sure to pry the metal keyboard base and not the keycaps.
  7. Samsung NP-R540-JA09US Front Panel Replacement: étape 8, image 1 de 1
    • Do not bend your keyboard as shown in this picture.
    • Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
  8. Samsung NP-R540-JA09US Front Panel Replacement: étape 9, image 1 de 2 Samsung NP-R540-JA09US Front Panel Replacement: étape 9, image 2 de 2
    • Disconnect the keyboard cable from the motherboard.
  9. Samsung NP-R540-JA09US Front Panel Replacement, Front Panel: étape 10, image 1 de 1
    • Remove the two screws with a Phillips #00 screwdriver.
  10. Samsung NP-R540-JA09US Front Panel Replacement: étape 11, image 1 de 1
    • Remove the highlighted screws with a Phillips #0 Screwdriver.
  11. Samsung NP-R540-JA09US Front Panel Replacement: étape 12, image 1 de 3 Samsung NP-R540-JA09US Front Panel Replacement: étape 12, image 2 de 3 Samsung NP-R540-JA09US Front Panel Replacement: étape 12, image 3 de 3
    • Pry the front panel away from the base with an Opening Tool.
  12. Samsung NP-R540-JA09US Front Panel Replacement: étape 13, image 1 de 2 Samsung NP-R540-JA09US Front Panel Replacement: étape 13, image 2 de 2
    • Disconnect the speaker wire from the motherboard.
Daylyn Bourland
Membre depuis le 09/21/18
285 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 457
