Aller au contenu principal
Samsung NP305E5A-A03US Optical Drive Replacement
Ce dont vous avez besoin
  1. Samsung NP305E5A-A03US Optical Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US Optical Drive Replacement: étape 2, image 1 de 1
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US Optical Drive Replacement: étape 3, image 1 de 2 Samsung NP305E5A-A03US Optical Drive Replacement: étape 3, image 2 de 2
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US Optical Drive Replacement: étape 4, image 1 de 1
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US Optical Drive Replacement: étape 5, image 1 de 2 Samsung NP305E5A-A03US Optical Drive Replacement: étape 5, image 2 de 2
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US Optical Drive Replacement: étape 6, image 1 de 1
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US Optical Drive Replacement, Optical Drive: étape 7, image 1 de 1
    • Unscrew the fourteen 9.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the two 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  8. Samsung NP305E5A-A03US Optical Drive Replacement: étape 8, image 1 de 2 Samsung NP305E5A-A03US Optical Drive Replacement: étape 8, image 2 de 2
    • Insert the plastic opening tool between the seam of the back panel and the laptop.
    • Slide the plastic opening tool along the seam to loosen the back panel from the laptop.
    • It may be difficult to slide the plastic opening tool along the seam, so you may have to apply some force.
  9. Samsung NP305E5A-A03US Optical Drive Replacement: étape 9, image 1 de 3 Samsung NP305E5A-A03US Optical Drive Replacement: étape 9, image 2 de 3 Samsung NP305E5A-A03US Optical Drive Replacement: étape 9, image 3 de 3
    • Remove the Back Panel by lifting it towards you.
    • It may take some force to remove the Back Panel.
  10. Samsung NP305E5A-A03US Optical Drive Replacement: étape 10, image 1 de 2 Samsung NP305E5A-A03US Optical Drive Replacement: étape 10, image 2 de 2
    • Remove the Optical Drive by sliding it away from the laptop.
Kris Stobbe
Membre depuis le 10/30/16
585 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team 5-7, Williams Fall 2016 Membre de l'équipe Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 316
