Aller au contenu principal
Samsung NP350E5C-A02US Optical Drive Replacement
Ce dont vous avez besoin
  1. Samsung NP350E5C-A02US Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US Optical Drive Replacement: étape 2, image 1 de 1
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US Optical Drive Replacement: étape 3, image 1 de 1
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US Optical Drive Replacement, Hard drive and memory stick cover: étape 4, image 1 de 1
    • Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
  5. Samsung NP350E5C-A02US Optical Drive Replacement: étape 5, image 1 de 1
    • Slide the cover 1/4" towards the front of the laptop.
  6. Samsung NP350E5C-A02US Optical Drive Replacement: étape 6, image 1 de 1
    • Then, lift the cover off.
  7. Samsung NP350E5C-A02US Optical Drive Replacement, Optical Drive: étape 7, image 1 de 1
    • Find the screw between the hard drive and the model label. Then remove the M2.5X5 screw with a Phillips #0 screwdriver.
  8. Samsung NP350E5C-A02US Optical Drive Replacement: étape 8, image 1 de 1
    • Pull the optical drive straight out.
James Kingrey
Membre depuis le 10/04/18
775 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 241
