Aller au contenu principal
Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement
Ce dont vous avez besoin
  1. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, Battery: étape 1, image 1 de 1
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement: étape 2, image 1 de 1
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement: étape 3, image 1 de 2 Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement: étape 3, image 2 de 2
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, ODD/HDD/Memory panel: étape 4, image 1 de 3 Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, ODD/HDD/Memory panel: étape 4, image 2 de 3 Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, ODD/HDD/Memory panel: étape 4, image 3 de 3
    • Locate the ODD/HDD/Memory panel.
    • Remove the 1.9 mm screw located on the ODD/HDD/Memory panel with the Philips #0 screwdriver.
    • Slide the ODD/HDD/Memory panel away from the device to remove it.
Mykel Vanek
Membre depuis le 09/21/17
334 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 26
Total : 1,428
