Aller au contenu principal
Samsung NP510R5E-A01UB Speaker Replacement
Ce dont vous avez besoin
  1. Samsung NP510R5E-A01UB Speaker Replacement, Hard Drive: étape 1, image 1 de 1
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Speaker Replacement: étape 2, image 1 de 1
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Speaker Replacement: étape 3, image 1 de 2 Samsung NP510R5E-A01UB Speaker Replacement: étape 3, image 2 de 2
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Speaker Replacement, Speaker: étape 4, image 1 de 3 Samsung NP510R5E-A01UB Speaker Replacement, Speaker: étape 4, image 2 de 3 Samsung NP510R5E-A01UB Speaker Replacement, Speaker: étape 4, image 3 de 3
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Speaker Replacement: étape 5, image 1 de 2 Samsung NP510R5E-A01UB Speaker Replacement: étape 5, image 2 de 2
    • Untangle the wires attached to the exterior of the right speaker.
    • Lift the tape up holding the wires down to fully release the wires.
  6. Samsung NP510R5E-A01UB Speaker Replacement: étape 6, image 1 de 1
    • Unscrew the 3.4mm long screw holding the right speaker in place.
  7. Samsung NP510R5E-A01UB Speaker Replacement: étape 7, image 1 de 1
    • Pull up on the wires circled to disconnect the right speaker.
  8. Samsung NP510R5E-A01UB Speaker Replacement: étape 8, image 1 de 1
    • Using the plastic opening tool, pry up the right speaker and take it out.
  9. Samsung NP510R5E-A01UB Speaker Replacement: étape 9, image 1 de 1
    • Unscrew the 3.4mm long screw holding the left speaker in place.
  10. Samsung NP510R5E-A01UB Speaker Replacement: étape 10, image 1 de 1
    • Pull up on the wires to disconnect the left speaker.
  11. Samsung NP510R5E-A01UB Speaker Replacement: étape 11, image 1 de 1
    • Using the plastic opening tool, pry up the left speaker and take it out.
Brian Briggs
Membre depuis le 02/14/18
529 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S6-G5, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S6-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S6G5
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 281
