Introduction
In this guide you will be learning how to remove the back cover from your Samsung NP5230U4BL laptop. This will enable you to replace a damaged back cover or access internal components such as the battery, CD drive, RAM, etc. Before attempting to remove the back cover, be sure to have a Philips #00 Screwdriver and a Nylon pry tool on standby. Also carefully follow the given instructions including the cautionary warnings.
Ce dont vous avez besoin
Using the Phillips #00 screwdriver, remove all ten 1.5 mm screws from the back cover of the laptop.
