Aller au contenu principal
Samsung NP700Z5AH Battery Replacement
Ce dont vous avez besoin
  1. Samsung NP700Z5AH Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
  2. Samsung NP700Z5AH Battery Replacement: étape 2, image 1 de 3 Samsung NP700Z5AH Battery Replacement: étape 2, image 2 de 3 Samsung NP700Z5AH Battery Replacement: étape 2, image 3 de 3
    • Using your fingers, pinch the edge of the SD card and pull to remove it.
  3. Samsung NP700Z5AH Battery Replacement: étape 3, image 1 de 2 Samsung NP700Z5AH Battery Replacement: étape 3, image 2 de 2
    • Wedge your fingers in between the upper case and the lower case
    • Gently pull the lower case away from the upper case to remove it
  4. Samsung NP700Z5AH Battery Replacement: étape 4, image 1 de 2 Samsung NP700Z5AH Battery Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
    • Be sure to pull straight backwards, or you risk damaging the wires.
  5. Samsung NP700Z5AH Battery Replacement: étape 5, image 1 de 1
    • Remove the two 4.4mm Phillips#00 screws from the battery case.
  6. Samsung NP700Z5AH Battery Replacement: étape 6, image 1 de 2 Samsung NP700Z5AH Battery Replacement: étape 6, image 2 de 2
    • Place your fingers on the corner sections of the battery.
    • Lift to remove the battery.
    • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
5 autres ont terminé cette réparation.
Erik
Membre depuis le 09/27/17
871 Réputation
6 tutoriels rédigés
Un commentaire
ifixit@distinctlydifferent.co.uk
Jacqueline - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 23
Total : 1,000
