Aller au contenu principal
Samsung NP900X4B Fan Replacement
Ce dont vous avez besoin
  1. Samsung NP900X4B Fan Replacement, Back Panel: étape 1, image 1 de 2 Samsung NP900X4B Fan Replacement, Back Panel: étape 1, image 2 de 2
    • First turn the computer over so you are looking at the back panel.
    • Next locate all ten Phillips #0 3.5mm screws on the back panel that are securing it down.
  2. Samsung NP900X4B Fan Replacement: étape 2, image 1 de 1
    • Next remove all 3.5mm Phillips #0 screws shown in the previous step.
  3. Samsung NP900X4B Fan Replacement: étape 3, image 1 de 2 Samsung NP900X4B Fan Replacement: étape 3, image 2 de 2
    • After all screws are removed, lift up the back panel as shown.
  4. Samsung NP900X4B Fan Replacement, Fan: étape 4, image 1 de 2 Samsung NP900X4B Fan Replacement, Fan: étape 4, image 2 de 2
    • Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
  5. Samsung NP900X4B Fan Replacement: étape 5, image 1 de 1
    • After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
  6. Samsung NP900X4B Fan Replacement: étape 6, image 1 de 2 Samsung NP900X4B Fan Replacement: étape 6, image 2 de 2
    • Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
  7. Samsung NP900X4B Fan Replacement: étape 7, image 1 de 1
    • Once the cable has been removed from its housing you are free to remove the fan from the laptop.
    • You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
Brian Miller
Membre depuis le 10/17/18
333 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 Membre de l'équipe UMass Dartmouth, Team S4-G6, Valliere Fall 2018
UMASSD-VALLIERE-F18S4G6
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 194
