Aller au contenu principal
Samsung NP900X4B RAM Replacement
Ce dont vous avez besoin
  1. Samsung NP900X4B RAM Replacement, RAM: étape 1, image 1 de 1
    • This guide should be attempted after the removal of the back panel is completed.
    • The Battery Removal guide demonstrates how to do this. The link to this guide is posed here. Samsung NP900X4B Battery Replacement
  2. Samsung NP900X4B RAM Replacement: étape 2, image 1 de 1
    • Locate the two sticks or DDR3 RAM. They can be found in the upper right-hand corner.
  3. Samsung NP900X4B RAM Replacement: étape 3, image 1 de 3 Samsung NP900X4B RAM Replacement: étape 3, image 2 de 3 Samsung NP900X4B RAM Replacement: étape 3, image 3 de 3
    • Use a plastic opening tool to nudge one clamp holding one stick of RAM outward. If done correctly the clamp should move away from the stick of RAM. Do this with the clamp on the opposite side of the same stick or RAM. The stick of RAM will pop up when both clamps are released
  4. Samsung NP900X4B RAM Replacement: étape 4, image 1 de 1
    • Repeat step 3 with the second stick of RAM. Again, when this is done correctly the RAM should pop up at an angle away from the laptop.
  5. Samsung NP900X4B RAM Replacement: étape 5, image 1 de 1
    • Perform the previous steps in the reverse order to install two new sticks of RAM into the DDR3 slots. Make sure that the clamps click back in place. Failure to do so could result in non responsive sticks of RAM. If this is an issue, not to worry. Try taking the clamps off and reinstering the RAM.
Bryton Lawrence
Membre depuis le 10/17/18
327 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 Membre de l'équipe UMass Dartmouth, Team S4-G6, Valliere Fall 2018
UMASSD-VALLIERE-F18S4G6
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 237
