Aller au contenu principal
Samsung NP900X4B Wifi Card Replacement
Ce dont vous avez besoin
  1. Samsung NP900X4B Wifi Card Replacement, Wifi Card: étape 1, image 1 de 1
    • This guide should be attempted after the removal of the back panel is completed.
    • The Battery Removal guide demonstrates how to do this. The link to this guide is posed here. Samsung NP900X4B Battery Replacement
  2. Samsung NP900X4B Wifi Card Replacement: étape 2, image 1 de 1
    • In order to continue, you need to observe the inside of the laptop and find where the Wifi Card is located.
  3. Samsung NP900X4B Wifi Card Replacement: étape 3, image 1 de 1
    • After finding the Wifi Card, you will discover two more 2.5mm Phillips #00 screws which hold the card in place.
    • The screws locations are shown in the image.
    • The same bit piece will be used to unscrew these (PH00/PH000). After completing this continue to the next step.
  4. Samsung NP900X4B Wifi Card Replacement: étape 4, image 1 de 2 Samsung NP900X4B Wifi Card Replacement: étape 4, image 2 de 2
    • There will be two wires connecting to the Wifi Card from the laptop.
    • These wires can be removed with one of the plastic tools in the iFixit toolkit by applying slight force onto them.
    • After removing the wires move on to the next step.
  5. Samsung NP900X4B Wifi Card Replacement: étape 5, image 1 de 2 Samsung NP900X4B Wifi Card Replacement: étape 5, image 2 de 2
    • This last step is the easiest of them all, all you need to do it pick up the Wifi Card from its position and you're done!
    • Now you are able to replace the card by following these steps in reverse or have the card further repaired.
Jacob Drohan
Membre depuis le 10/15/18
121 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 Membre de l'équipe UMass Dartmouth, Team S4-G6, Valliere Fall 2018
UMASSD-VALLIERE-F18S4G6
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 241
