Aller au contenu principal
Samsung NX Mini LCD Replacement
Ce dont vous avez besoin
  1. Samsung NX Mini LCD Replacement, Battery: étape 1, image 1 de 3 Samsung NX Mini LCD Replacement, Battery: étape 1, image 2 de 3 Samsung NX Mini LCD Replacement, Battery: étape 1, image 3 de 3
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Samsung NX Mini LCD Replacement: étape 2, image 1 de 2 Samsung NX Mini LCD Replacement: étape 2, image 2 de 2
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
  3. Samsung NX Mini LCD Replacement, Front Case: étape 3, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Samsung NX Mini LCD Replacement: étape 4, image 1 de 1
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
  5. Samsung NX Mini LCD Replacement: étape 5, image 1 de 1
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. Samsung NX Mini LCD Replacement: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  7. Samsung NX Mini LCD Replacement: étape 7, image 1 de 1
    • Use tweezers to remove the inner metal ring.
  8. Samsung NX Mini LCD Replacement: étape 8, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  9. Samsung NX Mini LCD Replacement: étape 9, image 1 de 2 Samsung NX Mini LCD Replacement: étape 9, image 2 de 2
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
  10. Samsung NX Mini LCD Replacement, Sensor: étape 10, image 1 de 3 Samsung NX Mini LCD Replacement, Sensor: étape 10, image 2 de 3 Samsung NX Mini LCD Replacement, Sensor: étape 10, image 3 de 3
    • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
    • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
    • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
  11. Samsung NX Mini LCD Replacement: étape 11, image 1 de 2 Samsung NX Mini LCD Replacement: étape 11, image 2 de 2
    • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
  12. Samsung NX Mini LCD Replacement: étape 12, image 1 de 3 Samsung NX Mini LCD Replacement: étape 12, image 2 de 3 Samsung NX Mini LCD Replacement: étape 12, image 3 de 3
    • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
    • Remove the battery compartment.
  13. Samsung NX Mini LCD Replacement: étape 13, image 1 de 2 Samsung NX Mini LCD Replacement: étape 13, image 2 de 2
    • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
  14. Samsung NX Mini LCD Replacement: étape 14, image 1 de 1
    • Gently remove the sensor mount from the camera case.
  15. Samsung NX Mini LCD Replacement, Flash Assembly: étape 15, image 1 de 3 Samsung NX Mini LCD Replacement, Flash Assembly: étape 15, image 2 de 3 Samsung NX Mini LCD Replacement, Flash Assembly: étape 15, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws holding the flash assembly to the camera case.
  16. Samsung NX Mini LCD Replacement: étape 16, image 1 de 2 Samsung NX Mini LCD Replacement: étape 16, image 2 de 2
    • Remove the flash assembly by gently pulling it away from the case.
    • You may need to use a spudger to release some of the clips holding the assembly in place.
    • Avoid touching the ends of the capacitor (the large black cylinder on the right). Capacitors that haven't been discharged may cause electric shock. Learn how to discharge a capacitor here.
  17. Samsung NX Mini LCD Replacement, LCD: étape 17, image 1 de 1
    • Remove the 5 mm Phillips #00 screw in the top right corner of the LCD assembly.
  18. Samsung NX Mini LCD Replacement: étape 18, image 1 de 2 Samsung NX Mini LCD Replacement: étape 18, image 2 de 2
    • Tilt and wiggle the LCD to remove it from the case.
Kelsea Weber
Membre depuis le 11/12/15
21 027 Réputation
32 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 678
