Aller au contenu principal
Introduction
Replacing the flash on the Samsung NX30 is a bit of a challenge. It requires soldering. Make sure when you are performing this replacement to not touch the metal leads on either side of the flash bulb because they will shock you.
  1. Samsung NX30 Flash Replacement, Battery: étape 1, image 1 de 1
    • Flip the camera over so that the bottom of the camera is up.
    • Push the battery switch towards the back of the camera.
  2. Samsung NX30 Flash Replacement: étape 2, image 1 de 2 Samsung NX30 Flash Replacement: étape 2, image 2 de 2
    • Locate the blue switch above the battery pack.
    • Slide the blue switch into the camera in the direction of the arrow on the switch. When the switch has been pushed in the battery will spring up.
  3. Samsung NX30 Flash Replacement: étape 3, image 1 de 1
    • Pull the battery out.
  4. Samsung NX30 Flash Replacement, Flash: étape 4, image 1 de 1
    • If you are looking at the front of the camera with the lens facing you, look at the right side of the camera, press the flash button to pop up the flash head.
  5. Samsung NX30 Flash Replacement: étape 5, image 1 de 2 Samsung NX30 Flash Replacement: étape 5, image 2 de 2
    • Once the flash head is up, unscrew the two black 4mm Phillips head screws located on either side of the flash bulb.
  6. Samsung NX30 Flash Replacement: étape 6, image 1 de 1
    • Once the screws have been removed, push the flash head back down.
  7. Samsung NX30 Flash Replacement: étape 7, image 1 de 3 Samsung NX30 Flash Replacement: étape 7, image 2 de 3 Samsung NX30 Flash Replacement: étape 7, image 3 de 3
    • After closing the flash head, pull the black flash head cover up and off of the flash head.
  8. Samsung NX30 Flash Replacement: étape 8, image 1 de 2 Samsung NX30 Flash Replacement: étape 8, image 2 de 2
    • Once the flash cover has been removed, unscrew the two silver 3mm Phillips head screws located on the top of the flash head.
    • Do not touch the metal leads on either side of the flash, and avoid touching any metal. The capacitor may be charged and it will shock you.
  9. Samsung NX30 Flash Replacement: étape 9, image 1 de 1
    • Once the screws have been removed, pull the flash bulb out from the camera.
    • Then remove the flash from the camera by soldering the flash bulb off, using a soldering iron.
    • For tips on soldering, check out the Soldering Technique Guide.
William
Membre depuis le 03/02/2016
179 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team 1-4, Rose Winter 2016 Membre de l'équipe UW Tacoma, Team 1-4, Rose Winter 2016
UWT-ROSE-W16S1G4
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 738
