Introduction
After troubleshooting any audio issues, you may decide to replace your speakers. This guide will walk you through the removal and replacement of the left and right speakers in your Samsung Notebook 5 NP530E5M. Once you remove the back panel and unplug the battery for safety, you may follow this guide to replace one or both of your faulty speakers.
Please note: New internal speakers are typically sold in pairs. It is recommended to replace both speakers at the same time, so you are sure they will function properly together, and to ensure that if your issues were with the hardware, they will not continue.
Ce dont vous avez besoin
Flip the laptop over to access the bottom case.
Using a Phillips #000 screwdriver, remove the ten 6mm screws that secure the bottom case.
Using the pry tool, loosen the wire connecting the speaker to the motherboard.
Carefully disconnect the right speaker wire from motherboard.
