Aller au contenu principal
Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Battery: étape 1, image 1 de 1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 2, image 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 2, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 3, image 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 3, image 2 de 2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 4, image 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 4, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 5, image 1 de 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 5, image 2 de 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 5, image 3 de 3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 1 de 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 2 de 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 3 de 3
    • Use the Phillips #00 screwdriver to remove the two 4.5mm screws holding the cover plate in place.
  7. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 7, image 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 7, image 2 de 2
    • Remove the black ribbon cable by pulling up on the black cover and sliding out the cable.
  8. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 8, image 1 de 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 8, image 2 de 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 8, image 3 de 3
    • Remove the three black and white cables by gently pulling on them.
  9. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 9, image 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: étape 9, image 2 de 2
    • Use the Phillips #00 screwdriver to remove the two 4.5mm screws holding the USB board down and remove the board.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 15
Total : 751
