Aller au contenu principal
Samsung PL200 Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung PL200 Motherboard Replacement, Motherboard: étape 1, image 1 de 2 Samsung PL200 Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Remove the two 3mm black external scews from he camera's side using the #000 Philips Screwdriver.
    • Remove the five 3mm silver external screws from the camera's side and bottom using the #000 Philips Screwdriver
  2. Samsung PL200 Motherboard Replacement: étape 2, image 1 de 3 Samsung PL200 Motherboard Replacement: étape 2, image 2 de 3 Samsung PL200 Motherboard Replacement: étape 2, image 3 de 3
    • Use the Plastic Opening Tool and your finger to pry off and remove the external cover.
  3. Samsung PL200 Motherboard Replacement: étape 3, image 1 de 3 Samsung PL200 Motherboard Replacement: étape 3, image 2 de 3 Samsung PL200 Motherboard Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the 3mm screw holding the circuit board using the #000 Philips Screwdriver.
    • Remove any tape on the circuit board and screen.
    • Using Tweezers, unplug the wires from the circuit board and remove it.
  4. Samsung PL200 Motherboard Replacement: étape 4, image 1 de 2 Samsung PL200 Motherboard Replacement: étape 4, image 2 de 2
    • Flip the LCD screen forward and remove the two 3mm screws beneath it using the #000 Phillips Screwdriver.
    • Remove the metal brace using the Plastic Opening Tool.
  5. Samsung PL200 Motherboard Replacement: étape 5, image 1 de 2 Samsung PL200 Motherboard Replacement: étape 5, image 2 de 2
    • Lift the black latch where the screen plugs into the motherboard and pull the cord to remove the screen
    • Separate the screen and the metal brace from the camera body.
  6. Samsung PL200 Motherboard Replacement: étape 6, image 1 de 1
    • Remove the front cover of the camera using your fingers and the Plastic Opening Tool.
  7. Samsung PL200 Motherboard Replacement: étape 7, image 1 de 1
    • Set the screen and metal brace aside
    • Open the camera's battery cover.
  8. Samsung PL200 Motherboard Replacement: étape 8, image 1 de 1
    • Using the #000 Phillips Screwdriver, remove the two 3mm screws holding the motherboard in place.
    • There may be tape still on the motherboard, if so, remove it.
  9. Samsung PL200 Motherboard Replacement: étape 9, image 1 de 3 Samsung PL200 Motherboard Replacement: étape 9, image 2 de 3 Samsung PL200 Motherboard Replacement: étape 9, image 3 de 3
    • Use the Tweezers to remove the tape from bottom of the camera
    • Use the Tweezers to disconnect the lens unit cord that is at the bottom of the camera from the motherboard.
    • Remove the last 3mm screw that holds the motherboard in place.
  10. Samsung PL200 Motherboard Replacement: étape 10, image 1 de 3 Samsung PL200 Motherboard Replacement: étape 10, image 2 de 3 Samsung PL200 Motherboard Replacement: étape 10, image 3 de 3
    • Use the Tweezers to unplug the small lens unit cord from the camera frame on the back side of the camera.
    • Gently lift the lens unit from the frame.
    • Separate the lens unit, motherboard, and camera.
  11. Samsung PL200 Motherboard Replacement: étape 11, image 1 de 3 Samsung PL200 Motherboard Replacement: étape 11, image 2 de 3 Samsung PL200 Motherboard Replacement: étape 11, image 3 de 3
    • Use the Tweezers to remove the small cord from motherboard.
    • Use the Tweezers to remove the first large lens unit cord from the motherboard.
    • Use the Tweezers to remove the second large lens unit cord from the motherboard.
  12. Samsung PL200 Motherboard Replacement: étape 12, image 1 de 2 Samsung PL200 Motherboard Replacement: étape 12, image 2 de 2
    • Desolder the four wires from the old motherboard.
  13. Samsung PL200 Motherboard Replacement: étape 13, image 1 de 2 Samsung PL200 Motherboard Replacement: étape 13, image 2 de 2
    • Last, solder on a functional motherboard at this stage and reassemble the device.
Marcus Lee
Membre depuis le 01/29/15
101 Réputation
1 tutoriel rédigé
Équipe
Clemson, Team 15-7, Shirley Winter 2015 Membre de l'équipe Clemson, Team 15-7, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G7
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 17
Total : 518
