Introduction
A tweeter speaker its the speaker that drives the highest range of frequency in the speaker. This guide will serve as a reference to replace the speaker/tweeter in the Samsung Radiant 360 R1 in the case that it becomes damaged.
Ce dont vous avez besoin
Use the plastic opening tool to lift and remove the rubber grommet plugs.
Remove the four (9.5mm x 1.6mm) PH1 Phillips screws on the port speaker body.
Remove the Port Panel exposing the subwoofer.
3 autres ont terminé cette réparation.
