Aller au contenu principal
Samsung Rogue Keyboard Replacement
Ce dont vous avez besoin
  1. Samsung Rogue Keyboard Replacement, Battery: étape 1, image 1 de 2 Samsung Rogue Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. Samsung Rogue Keyboard Replacement: étape 2, image 1 de 2 Samsung Rogue Keyboard Replacement: étape 2, image 2 de 2
    • You can now remove the battery by prying it up with your finger.
  3. Samsung Rogue Keyboard Replacement, Motherboard: étape 3, image 1 de 1
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  4. Samsung Rogue Keyboard Replacement: étape 4, image 1 de 1
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  5. Samsung Rogue Keyboard Replacement: étape 5, image 1 de 3 Samsung Rogue Keyboard Replacement: étape 5, image 2 de 3 Samsung Rogue Keyboard Replacement: étape 5, image 3 de 3
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  6. Samsung Rogue Keyboard Replacement: étape 6, image 1 de 1
    • Remove the two 3.45 mm Philips screws below the white sticker.
  7. Samsung Rogue Keyboard Replacement: étape 7, image 1 de 2 Samsung Rogue Keyboard Replacement: étape 7, image 2 de 2
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  8. Samsung Rogue Keyboard Replacement: étape 8, image 1 de 2 Samsung Rogue Keyboard Replacement: étape 8, image 2 de 2
    • Use a plastic opening tool to disconnect the film from the motherboard.
  9. Samsung Rogue Keyboard Replacement, Keyboard: étape 9, image 1 de 1
    • Remove the eight 1.7mm Philips screws above the keyboard.
  10. Samsung Rogue Keyboard Replacement: étape 10, image 1 de 1
    • Carefully remove keyboard holder from the slider mechanisms underneath.
  11. Samsung Rogue Keyboard Replacement: étape 11, image 1 de 2 Samsung Rogue Keyboard Replacement: étape 11, image 2 de 2
    • Turn keyboard holder over and allow the keyboard to simply fall out into your hand.
Viktoria Mikoultchik
Membre depuis le 04/15/12
25 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 7-32, Maness Spring 2012 Membre de l'équipe Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 299
