Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
This guide will provide a step-by-step procedure for getting to the main motherboard in your Samsung Rogue.
Pièces
Aucune pièce spécifiée.
  1. Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  2. Remove the five 3.4mm Philips screws securing the backing of the phone.
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  3. Use a plastic opening tool to carefully pry off the back cover. Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other. Be careful to not drop the volume changing piece, for it can easily slip out.
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  4. Remove the two 3.45 mm Philips screws below the white sticker.
    • Remove the two 3.45 mm Philips screws below the white sticker.
  5. Carefully lift the motherboard up from the bottom edge. The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  6. Use a plastic opening tool to disconnect the film from the motherboard. Use a plastic opening tool to disconnect the film from the motherboard.
    • Use a plastic opening tool to disconnect the film from the motherboard.
Viktoria Mikoultchik
Membre depuis le 15/04/2012
25 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 7-32, Maness Spring 2012 Membre de l'équipe Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 membres
16 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 181
