Aller au contenu principal
Introduction
The disassembly of the covers will be needed to replace/repair anything on the Samsung SCV-VLUUST50, not including the battery.
Pièces
Aucune pièce spécifiée.
  1. Unscrew all visible screws indicated by red circles with a #00 Phillips driver. Slide memory card cover and unscrew hidden screw  underneath with a #00 Phillips driver. Slide memory card cover and unscrew hidden screw  underneath with a #00 Phillips driver.
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Remove the flat side panel by applying gentle pressure toward the bottom of the camera. Remove the corner panel by applying pressure away from the shutter button. The memory card cover will come off with the corner panel.
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  5. Remove the front and back covers by pulling them straight apart. Remove the front and back covers by pulling them straight apart.
    • Remove the front and back covers by pulling them straight apart.
Jade Withrow
Membre depuis le 08/02/2018
255 Réputation
2 tutoriels rédigés
Équipe
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 70
