Introduction
Is your flash weak or not working at all? It could be your flash capacitor. Here's a replacement guide to help.
Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
  • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
  • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
Ajouter un commentaire
Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
  • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
  • Remove the corner panel by applying pressure away from the shutter button.
  • The memory card cover will come off with the corner panel.
  • Remove the top panel by applying gentle pressure away from the shutter button.
  • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  • Remove the front and back covers by pulling them straight apart.
  • Remove the screw securing the shutter button.
  • Lift the shutter button to remove it.
  • Remove the 3 visible screws with a Phillips #000 Driver
  • Move the circuitry and wires out of the way to expose another screw, and remove it with the same driver.
  • Pull the flash capacitor out of its compartment to expose the wires connected to it.
  • Cut the connecting wires with wire cutters.
  • Solder the wires to the new power source with a soldering iron and electrical solder.
Evert Jordan
Membre depuis le 08/02/2018
281 Réputation
2 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 49
