Introduction
Is your screen broken or faulty? This guide will help you replace it.
Pièces
Aucune pièce nécessaire.
Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
  • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
  • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
Ajouter un commentaire
Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
  • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
  • Remove the corner panel by applying pressure away from the shutter button.
  • The memory card cover will come off with the corner panel.
  • Remove the top panel by applying gentle pressure away from the shutter button.
  • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  • Remove the front and back covers by pulling them straight apart.
  • Open the ribbon connector with your fingernail.
  • Pull the ribbon out of the connection.
  • Pull the ribbon connected to the screen out from behind the button circuitry on the rear of the camera.
  • Feed the new screen's ribbon through the same slot it came out of.
Evert Jordan
Membre depuis le 08/02/2018
281 Réputation
2 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 9
