Aller au contenu principal
Samsung SGH-T639 Keypad Replacement
Ce dont vous avez besoin
  1. Samsung SGH-T639 Keypad Replacement, Battery: étape 1, image 1 de 1
    • Flip the phone over and take off the back cover
    • Note: These images do not contain the back cover or battery of the phone.
  2. Samsung SGH-T639 Keypad Replacement: étape 2, image 1 de 1
    • Use button to remove battery from the phone.
  3. Samsung SGH-T639 Keypad Replacement, SIM Card: étape 3, image 1 de 3 Samsung SGH-T639 Keypad Replacement, SIM Card: étape 3, image 2 de 3 Samsung SGH-T639 Keypad Replacement, SIM Card: étape 3, image 3 de 3
    • Locate SIM card
    • Slide SIM card down and gently pull out of the card slot
  4. Samsung SGH-T639 Keypad Replacement, Motherboard: étape 4, image 1 de 3 Samsung SGH-T639 Keypad Replacement, Motherboard: étape 4, image 2 de 3 Samsung SGH-T639 Keypad Replacement, Motherboard: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Locate the six (4mm) screws on the back casing of the phone.
    • Unscrew each one using a phillips head #000 screwdriver.
    • Place screws on magnetic mat.
  5. Samsung SGH-T639 Keypad Replacement: étape 5, image 1 de 3 Samsung SGH-T639 Keypad Replacement: étape 5, image 2 de 3 Samsung SGH-T639 Keypad Replacement: étape 5, image 3 de 3
    • Starting at the top of the phone, carefully insert plastic opening device into the seam.
    • Carefully slide device along the seam and around the corners of the phone until the back is separated from the front.
    • Note: Some force must be exerted. Be careful when taking off panel. Go slow.
    • Note: The volume button may separate from the case, this is normal. It is not broken.
  6. Samsung SGH-T639 Keypad Replacement: étape 6, image 1 de 3 Samsung SGH-T639 Keypad Replacement: étape 6, image 2 de 3 Samsung SGH-T639 Keypad Replacement: étape 6, image 3 de 3
    J'achète
    • Locate the connection point of black wire running from the microphone to the motherboard.
    • Carefully disconnect the gold connector from the motherboard using tweezers.
  7. Samsung SGH-T639 Keypad Replacement: étape 7, image 1 de 3 Samsung SGH-T639 Keypad Replacement: étape 7, image 2 de 3 Samsung SGH-T639 Keypad Replacement: étape 7, image 3 de 3
    • Locate the red connector at the top of the motherboard.
    • Carefully lift and remove the connector from the motherboard using tweezers.
  8. Samsung SGH-T639 Keypad Replacement: étape 8, image 1 de 3 Samsung SGH-T639 Keypad Replacement: étape 8, image 2 de 3 Samsung SGH-T639 Keypad Replacement: étape 8, image 3 de 3
    • Locate the gold connector that connects the screen to the motherboard.
    • Carefully disconnect the connector from the motherboard using tweezers.
  9. Samsung SGH-T639 Keypad Replacement: étape 9, image 1 de 3 Samsung SGH-T639 Keypad Replacement: étape 9, image 2 de 3 Samsung SGH-T639 Keypad Replacement: étape 9, image 3 de 3
    • Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool.
    • Lift the motherboard from the cell phone.
  10. Samsung SGH-T639 Keypad Replacement: étape 10, image 1 de 1
    • Remove the motherboard from the cell phone.
  11. Samsung SGH-T639 Keypad Replacement, Keypad: étape 11, image 1 de 2 Samsung SGH-T639 Keypad Replacement, Keypad: étape 11, image 2 de 2
    • Locate the two black, rubber tabs near the top of the back of the phone.
    • Locate the one black, rubber tab near the base of the phone.
  12. Samsung SGH-T639 Keypad Replacement: étape 12, image 1 de 3 Samsung SGH-T639 Keypad Replacement: étape 12, image 2 de 3 Samsung SGH-T639 Keypad Replacement: étape 12, image 3 de 3
    J'achète
    • Using tweezers, pry each of the tabs open.
    • Tuck each tab behind the white notch.
    • By tucking the tabs behind each notch. This allows improves the ease of removing the keypad.
  13. Samsung SGH-T639 Keypad Replacement: étape 13, image 1 de 3 Samsung SGH-T639 Keypad Replacement: étape 13, image 2 de 3 Samsung SGH-T639 Keypad Replacement: étape 13, image 3 de 3
    • Flip phone over to make the keypad visable.
    • Carefully lift keypad around the edges.
    • Remove keypad from the cell phone.
Yi Ren
Membre depuis le 03/26/14
801 Réputation
8 tutoriels rédigés
Équipe
Clemson, Team 1-4, Benson Spring 2014 Membre de l'équipe Clemson, Team 1-4, Benson Spring 2014
CLEM-BENSON-S14S1G4
3 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 318
