Aller au contenu principal
Samsung SGH-X495 Microphone Replacement
Ce dont vous avez besoin
  1. Samsung SGH-X495 Microphone Replacement, Backplate: étape 1, image 1 de 1
    • Remove the 4 (4.7mm) philips head screws.
  2. Samsung SGH-X495 Microphone Replacement: étape 2, image 1 de 1
    • Unplug the rubber charger outlet cover.
  3. Samsung SGH-X495 Microphone Replacement: étape 3, image 1 de 1
    • Unplug the rubber headset jack cover.
  4. Samsung SGH-X495 Microphone Replacement: étape 4, image 1 de 2 Samsung SGH-X495 Microphone Replacement: étape 4, image 2 de 2
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
  5. Samsung SGH-X495 Microphone Replacement: étape 5, image 1 de 2 Samsung SGH-X495 Microphone Replacement: étape 5, image 2 de 2
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
  6. Samsung SGH-X495 Microphone Replacement, Motherboard: étape 6, image 1 de 1
    • Remove the ribbon wires connecting to the screen using the pry tool.
  7. Samsung SGH-X495 Microphone Replacement: étape 7, image 1 de 1
    • 2 tabs hold the motherboard in place.
    • Release the labeled tabs with the pry tool from the location shown.
  8. Samsung SGH-X495 Microphone Replacement: étape 8, image 1 de 1
    • Separate the motherboard from the phone.
  9. Samsung SGH-X495 Microphone Replacement, Microphone: étape 9, image 1 de 1
    • Solder joints are accessable to replace the microphone.
Matthew Hove
Membre depuis le 01/05/11
1 031 Réputation
10 tutoriels rédigés
Équipe
Cal Poly, Team 3-40, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 membres
20 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,806
