Introduction
Is your display screen cracked or not operating correctly? Replace it by following these steps.
Ce dont vous avez besoin
Once the battery pack is removed from the phone, remove the five indicated screws with a size #00 Philips screwdriver.
Bend back the antenna to access the indicated left middle screw in order to unscrew it.
To start, remove the two highlighted sticky covers using the blue prying tool or your finger. Prying off the stickers allows access to the screws underneath.
Slide the tool or your fingernail under the stickers and they should come off with relative ease.
Next, insert a plastic opening tool into the crack that runs along the side of the phone display under the screws. Doing so will start lift the display screen.
Once you have the display cover open, use your fingers to pry the whole outside cover off. Only do so to the top half of the phone.
Set the outside display cover aside. The two separate parts should look like the third picture.
Carefully wedge a plastic opening tool between the hinge on the body of the phone.
Slowly pry the hinge from the body, as shown in the second picture. Set the phone down after when finished with this step.
Next, slide the connector cable out of the slot on the back side of the phone and the screen will be disconnected from the key pad body.
Snap the display screen cover on the back of the top half of the phone by sliding the two pieces together and then snapping it together around the edges.
Replace the two screws that were removed in step 8 to secure the top half of the phone.
Put the sticky covers back on the screws.
Insert the volume key into the right side of the phone with the larger part of the volume key towards the top.
Snap on the back of the phone onto the logic board.
Screw in the five screws that were removed in step 3 to secure the back of the phone.
Put the battery back on the phone.
