Aller au contenu principal
Samsung SPH-A760 Speakers Replacement
Ce dont vous avez besoin
  1. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Battery: étape 1, image 1 de 2 Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Battery: étape 1, image 2 de 2
    • Push open the latch and remove the battery.
  2. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Antenna: étape 2, image 1 de 2 Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Antenna: étape 2, image 2 de 2
    • Twist off the antenna.
    • Pop off the transparent cylinder.
  3. Samsung SPH-A760 Speakers Replacement, Logic Board: étape 3, image 1 de 1
    • Remove the five screws as shown.
  4. Samsung SPH-A760 Speakers Replacement: étape 4, image 1 de 1
    • Carefully pry the back plate off.
  5. Samsung SPH-A760 Speakers Replacement: étape 5, image 1 de 2 Samsung SPH-A760 Speakers Replacement: étape 5, image 2 de 2
    • Carefully detach golden screen connector.
  6. Samsung SPH-A760 Speakers Replacement: étape 6, image 1 de 2 Samsung SPH-A760 Speakers Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  7. Samsung SPH-A760 Speakers Replacement: étape 7, image 1 de 2 Samsung SPH-A760 Speakers Replacement: étape 7, image 2 de 2
    • Place the logic board on a clean tray.
  8. Samsung SPH-A760 Speakers Replacement, Speakers: étape 8, image 1 de 2 Samsung SPH-A760 Speakers Replacement, Speakers: étape 8, image 2 de 2
    • Remove the hinge on the phone.
    • Put pressure on the spring with the screwdriver to unhinge phone.
    • Make sure to pull the gold wire through, don't let it rip.
  9. Samsung SPH-A760 Speakers Replacement: étape 9, image 1 de 3 Samsung SPH-A760 Speakers Replacement: étape 9, image 2 de 3 Samsung SPH-A760 Speakers Replacement: étape 9, image 3 de 3
    • Remove the four screws as shown
    • Use the spudger to pry it open, excessive force may be necessary.
  10. Samsung SPH-A760 Speakers Replacement: étape 10, image 1 de 3 Samsung SPH-A760 Speakers Replacement: étape 10, image 2 de 3 Samsung SPH-A760 Speakers Replacement: étape 10, image 3 de 3
    • Remove the three screws that hold the big speaker
    • Caution: The wires are attached to the screen and should be removed with care.
David
Membre depuis le 04/19/10
25 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 10-43, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,954
