Introduction
Performing this guide will require no more than a finger.
Ce dont vous avez besoin
Locate the arrow on the panel of the rear side of the phone.
Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
Use the plastic opening tool to gently detach the golden strip from the logic board.
The strip should detach easily with little force required.
Flip open the phone so that the text on the keyboard is showing.
Place one or two fingers on the text side of the keyboard and apply pressure until the keyboard has been completely detached from the phone casing.
To reassemble your device, place the keyboard back into the phone casing and apply light pressure to ensure that it is back in place.
