Aller au contenu principal
Samsung ST76 Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung ST76 Motherboard Replacement, Back Panel: étape 1, image 1 de 3 Samsung ST76 Motherboard Replacement, Back Panel: étape 1, image 2 de 3 Samsung ST76 Motherboard Replacement, Back Panel: étape 1, image 3 de 3
    • Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
    • Do not mix the 5 screws; they are different sizes.
  2. Samsung ST76 Motherboard Replacement: étape 2, image 1 de 2 Samsung ST76 Motherboard Replacement: étape 2, image 2 de 2
    • Use your fingers to pull the back cover off.
  3. Samsung ST76 Motherboard Replacement, Screen: étape 3, image 1 de 2 Samsung ST76 Motherboard Replacement, Screen: étape 3, image 2 de 2
    • Separate the button panel to reveal the port holding the screen on.
    • Use a plastic opening tool to help with this task.
  4. Samsung ST76 Motherboard Replacement: étape 4, image 1 de 2 Samsung ST76 Motherboard Replacement: étape 4, image 2 de 2
    • Remove the yellow cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
  5. Samsung ST76 Motherboard Replacement, Motherboard: étape 5, image 1 de 3 Samsung ST76 Motherboard Replacement, Motherboard: étape 5, image 2 de 3 Samsung ST76 Motherboard Replacement, Motherboard: étape 5, image 3 de 3
    • Remove 2 3mm screws from the metal plate covering the motherboard and lens using a Phillips #00 screw driver.
  6. Samsung ST76 Motherboard Replacement: étape 6, image 1 de 3 Samsung ST76 Motherboard Replacement: étape 6, image 2 de 3 Samsung ST76 Motherboard Replacement: étape 6, image 3 de 3
    • Remove the 4 cables connecting the motherboard to the camera body.
2 autres ont terminé cette réparation.
Jessica Bain
Membre depuis le 03/11/15
393 Réputation
2 tutoriels rédigés
Équipe
Marist, Team 1-6, Laflen Spring 2015 Membre de l'équipe Marist, Team 1-6, Laflen Spring 2015
MARS-LAFLEN-S15S1G6
2 membres
8 tutoriels rédigés
3 commentaires
Thanks for great info. I should add that one can also clean the sensor. Sensor is circular plate with 3 screws at back of the lens. Now the camera is like new!
compand - Réponse
Where can you buy a replacement motherboard?
Demaree Wiitala - Réponse
ST76 and ST77 are very close relatives.
As it can be seen on the parts, some are marked: ”ST77”
Paul
Paul Cohen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 859
