Introduction
Replacing the power jack is an involved process. In order to reach this part it is necessary to remove several laptop hardware components. Follow the steps of this guide in order to complete the project.
Ce dont vous avez besoin
Place the computer upside down, with the battery pack facing away from you.
Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
Remove the disc drive by pulling it towards the outside of the computer.
Using the J0 Japanese Industrial Standard screwdriver, remove the two 7mm screws that hold down the plug-in to the disc drive.
Locate the power jack on the corner of the motherboard.
Locate the four connectors that hold the power jack to the motherboard.
After soldering the new power jack in place, reassemble your device by following these instructions in reverse order.
3 autres ont terminé cette réparation.
