Aller au contenu principal
Samsung Series 3 NP300E5A-A02UB Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Place the computer upside down, with the battery pack facing away from you.
  2. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 2, image 1 de 2 Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 2, image 2 de 2
    • Remove the battery by pushing out the locks on either end then pushing the battery away from you.
  3. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement, Panel: étape 3, image 1 de 1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
  4. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 4, image 1 de 2 Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 4, image 2 de 2
    • Pull the panel towards you to release it, then lift it off the computer.
  5. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 5, image 1 de 1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw next to the label “ODD."
    • Remove the three 4.5mm screws from around the memory drive nest.
  6. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 6, image 1 de 1
    • Using the J1 Japanese Industrial Standard screwdriver, remove the thirteen 9.5mm screws from the panel that cover the bottom of the computer.
  7. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 7, image 1 de 3 Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 7, image 2 de 3 Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 7, image 3 de 3
    • Begin removing the computer casing by prying beside the disk drive with the iFixit opening tool and the spudger, working counterclockwise.
    • Lift the panel from the computer.
  8. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement, Disc Drive: étape 8, image 1 de 1
    • Remove the disc drive by pulling it towards the outside of the computer.
  9. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement, Motherboard: étape 9, image 1 de 2 Samsung Series 3 NP300E5A-A02UB Motherboard Replacement, Motherboard: étape 9, image 2 de 2
    • Using the J0 Japanese Industrial Standard screwdriver, remove the two 7mm screws that hold down the plug-in to the disc drive.
  10. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 10, image 1 de 1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 3.5mm screw from the chip connected to the USB ports.
  11. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 11, image 1 de 2 Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 11, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using the tweezers, gently pry up the chip and ports, and unthread the wire from its holders, without crimping the wires.
  12. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 12, image 1 de 2 Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 12, image 2 de 2
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw holding down the chip next to the power prongs where the battery connects.
    • Gently pull the chip from its connector.
  13. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 13, image 1 de 2 Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 13, image 2 de 2
    • Gently pull up the aluminum strip from the top right corner of the computer and unthread the wire from the holders using the tweezers, without crimping the wire or tearing the aluminum.
  14. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 14, image 1 de 1
    • Disconnect the wire screen connection from its port by pulling upwards.
  15. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 15, image 1 de 2 Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 15, image 2 de 2
    • Gently pull up the speaker towers from either end of the computer.
  16. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 16, image 1 de 2 Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 16, image 2 de 2
    • Using the blunt tweezers, unthread the wires that connect the motherboard to the speakers from their holders, without crimping the wires.
  17. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 17, image 1 de 2 Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 17, image 2 de 2
    • Using the iFixit opening tool, gently pry up the plastic clasp that holds the keyboard power circuit down, and pull out the strip from the connection.
  18. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 18, image 1 de 1
    • Pull out the plastic cover to release the Kotl strip, then pull out the strip.
  19. Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 19, image 1 de 2 Samsung Series 3 NP300E5A-A02UB Motherboard Replacement: étape 19, image 2 de 2
    • Using the J0 Japanese Industrial Standard screwdriver, remove the four 4.5mm screws from the corners of the motherboard.
    • Lift the motherboard from the computer.
Timothy Johnson
Membre depuis le 02/14/19
726 Réputation
5 tutoriels rédigés
Équipe
2 commentaires
I used this guide to put the laptop back together after a motherboard swap as I totally forgot to number the screws! Doh
Great website I never knew about!
Mike Paterson - Réponse
Hi, I'd like to know if I can replace the hhd for a SSD and a higher memory ram cause fabric is 2gb I'd like to change it for a 8gb. Will I get a funcional computer? Mostly to work on word or use it for zoom and such
Orne - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 26
Total : 1,057
