Introduction
Outline what you are going to teach someone how to do.
  1. Make sure your Chromebook is powered off before you begin. Place the laptop on a flat surface with the bottom side facing up.
    • Make sure your Chromebook is powered off before you begin.
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel. The easiest way to do this is to use your fingernails to pick them out.
    • Remove all the seven screws in the bottom panel.
  2. Loosen the back cover panel by using the flathead screwdriver or the spudger. Loosen the back cover panel by using the flathead screwdriver or the spudger.
    • Loosen the back cover panel by using the flathead screwdriver or the spudger.
  3. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Vous avez déjà réparé quelque chose ? Vous êtes un génie.
    Partagez votre réparation avec le hashtag #ImAGenius
    Nous sommes tous des génies
  4. Once you work your way around, you can remove the panel. Once you work your way around, you can remove the panel.
    • Once you work your way around, you can remove the panel.
  5. Remove the single Phillip screw Disconnect the WWAN antennas from the I/O board Remove the WWAN board from the motherboard.
    • Remove the single Phillip screw
    • Disconnect the WWAN antennas from the I/O board
    • Remove the WWAN board from the motherboard.
2 autre(s) ont terminé cette réparation.
Helder Avelino
Membre depuis le 22/10/2013
849 Réputation
5 tutoriels rédigés
Équipe
University of Maryland, Team 1-7, Shastany Fall 2013 Membre de l'équipe University of Maryland, Team 1-7, Shastany Fall 2013
UMD-SHASTANY-F13S1G7
2 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 551
