Introduction
This guide will show how to remove the covers from the underside of the laptop, remove the battery, and replace it with the new battery.
Before beginning, make sure the laptop is completely powered off and it is not being charged via the power cord.
  • Before beginning, make sure the laptop is completely powered off and it is not being charged via the power cord.
  • Remove the single screw holding the hard drive cover in place. This screw is 6.7 mm long.
  • Take off the cover using the built-in lips for leverage.
Ajouter un commentaire
Remove the rest of the screws holding the entire back cover in place. There are 13 of these screws. These are 4.0 mm long.
  • Remove the rest of the screws holding the entire back cover in place. There are 13 of these screws. These are 4.0 mm long.
  • Remove the screws holding the cover on from under the hard drive cover. These are 6.7 mm long.
  • Remove the rubber pads near where the hard drive cover was using a sharp pair of tweezers.
  • Unscrew the 4 mm screws underneath these pads.
  • Remove the entire rest of the back cover.
  • There are snaps that hold the cover near the fan in place. Be careful not to break these.
  • Remove the tape holding the wires in place.
  • Unscrew the four 4.5 mm screws holding the battery in place.
  • Unscrew the two 6.7 mm screws at the top of the battery.
  • Unplug the battery from the motherboard.
  • Remove the battery from its position on the underside of the laptop.
7 autre(s) ont terminé cette réparation.
Timothy
Membre depuis le 30/01/2015
1 254 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 16-3, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 6
7 derniers jours : 98
30 derniers jours : 445
Total : 15,115
