Introduction
This guide will show how to remove the covers from the underside of the laptop, remove the battery, and replace it with the new battery.
Ce dont vous avez besoin
Power off the device. Remove the remaining screws holding the back cover in place:
Six 4.0 mm Phillips #00 screws.
Seven 6.7 mm Phillips #00 screws.
Remove the two rubber pads concealing the final bottom case screws.
Remove the two 4 mm Phillips #00 screws found under these pads.
There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
Remove the entire rest of the back cover.
Pull the battery connector towards the battery to disconnect it.
14 autres ont terminé cette réparation.
2 commentaires
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
If you have a computer connected to a power supply that will still allow it to work.
