Introduction
Proving once again that thin and light can still be repairable when thoughtfully designed, the Series 9 15" scores a near-perfect 9 out of 10.
Outils
Pièces
Aucune pièce spécifiée.
We could remove the motherboard at this point, but pause to take a look at this trackpad.
Seemingly held in place with just five screws, but we remove them and it won't budge.
Then we peel off this pair of taped-in brackets, pry from the top bracket, and successfully remove the trackpad assembly.
The Samsung Series 9 15" earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
All screws are Phillips screws.
RAM, SSD, and battery are all easily replaced.
Relatively flat, modular design means that most components can be replaced quickly without having to remove other obstructions.
A moderate amount of adhesive on the I/O board and trackpad brackets complicates some reassembly procedures.
Manufacturer does not provide user-accessible repair documentation.
7 autre(s) ont terminé cette réparation.
2 commentaires
how would one repair water vapor trapper in between the touch panel glass?
Sadly when you pulled back the bezel you missed that it’s not a separate LCD but part of the top cover those screws at the bottom just hold a panel in place at the bottom.
Good guide otherwise.
