Aller au contenu principal
Samsung Series 9 NP900X3A Laptop Battery Replacement
Ce dont vous avez besoin
  1. Samsung Series 9 NP900X3A Laptop Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 2, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 3, image 1 de 3 Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 3, image 2 de 3 Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 3, image 3 de 3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
  4. Samsung Series 9 NP900X3A Laptop Battery Replacement, Laptop Battery: étape 4, image 1 de 3 Samsung Series 9 NP900X3A Laptop Battery Replacement, Laptop Battery: étape 4, image 2 de 3 Samsung Series 9 NP900X3A Laptop Battery Replacement, Laptop Battery: étape 4, image 3 de 3
    • Remove the last three remaining 0.1mm screws attached to the battery.
    • Keep track of the screws and remember their placement. This will make it easier to replace the battery.
  5. Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 5, image 1 de 3 Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 5, image 2 de 3 Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 5, image 3 de 3
    • Remove the battery from the laptop by prying it out from its compartment.
    • The battery should be loose and can move for the next step.
    • You will need to use force to pry open the battery.
  6. Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 6, image 1 de 2 Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 6, image 2 de 2
    • Find the battery's output plug, and use a spudger or pointed precision tool to press on the indention in the middle of the plug to unlock.
    • Do not press too hard unlocking the plug or you will puncture plug's pins ruining the connector.
  7. Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 7, image 1 de 2 Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 7, image 2 de 2
    • Remove the connection from the motherboard and the battery, by carefully placing both hands on the wires and tug on the wires.
    • You will need to use some force, be cautious when removing this component. Pull the plug out slowly while applying pressure with the tool in necessary.
  8. Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 8, image 1 de 3 Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 8, image 2 de 3 Samsung Series 9 NP900X3A Laptop Battery Replacement: étape 8, image 3 de 3
    • Remove the battery and place it from the laptop. At this point you can replace the battery with a new one.
Zahir Sanchez
Membre depuis le 02/08/18
493 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 45
Total : 3,791
