Aller au contenu principal
Samsung Series 9 NP900X3C-A02US Touch Pad Replacement
Ce dont vous avez besoin
  1. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement, Touch Pad: étape 1, image 1 de 1
    • Shut down the laptop.
    • Power off the laptop by navigating the window icon on the bottom left and clicking on the power followed by shutdown.
  2. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: étape 2, image 1 de 2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: étape 2, image 2 de 2
    • Remove the back cover of the laptop by using a Phillips #00 screwdriver to remove ten 2 mm screws.
    • Pry out the bottom panel on all sides using a prying tool.
  3. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: étape 3, image 1 de 3 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: étape 3, image 2 de 3 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: étape 3, image 3 de 3
    • Unscrew the internal battery and disconnect it from the motherboard.
    • Remove all the cables, tapes by using the tools such as plastic spudgers.
    • Look for the ribbon cable connection and by using the spudger to pull up the clip and unlock the ribbon cable.
  4. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: étape 4, image 1 de 2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: étape 4, image 2 de 2
    • Peel out any tapes holding the touchpad carefully.
  5. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: étape 5, image 1 de 2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: étape 5, image 2 de 2
    • By using the prying tool unstick and detach the module.
  6. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: étape 6, image 1 de 2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: étape 6, image 2 de 2
    • Remove four 0.1mm screws using a Phillips #00 Screwdriver from the laptop.
    • Open the laptop a little bit to create space to drop the touchpad module by pushing it gently downwards.
    • After taking out the touchpad clean it especially at the edges and the corners by using rubbing alcohol and microfiber cloth.
Ghaniyah Gul
Membre depuis le 02/07/23
391 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team A-2, Gonzalez Spring 2023 Membre de l'équipe Gateway, Team A-2, Gonzalez Spring 2023
GCC-GONZALEZ-S23SAG2
5 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 162
