Aller au contenu principal
Samsung Series 9 NP900X4B-A02 Speaker Replacement
Ce dont vous avez besoin
  1. Samsung Series 9 NP900X4B-A02 Speaker Replacement, Battery: étape 1, image 1 de 2 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Battery: étape 1, image 2 de 2
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung Series 9 NP900X4B-A02 Speaker Replacement: étape 2, image 1 de 1
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung Series 9 NP900X4B-A02 Speaker Replacement: étape 3, image 1 de 2 Samsung Series 9 NP900X4B-A02 Speaker Replacement: étape 3, image 2 de 2
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung Series 9 NP900X4B-A02 Speaker Replacement: étape 4, image 1 de 1
    • Lift and pull out the battery.
  5. Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: étape 5, image 1 de 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: étape 5, image 2 de 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: étape 5, image 3 de 3
    • Unplug the left speaker's cable from the motherboard.
    • Lift up and remove the left speaker.
  6. Samsung Series 9 NP900X4B-A02 Speaker Replacement: étape 6, image 1 de 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement: étape 6, image 2 de 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement: étape 6, image 3 de 3
    • Unplug the right speaker's cable from the motherboard.
    • Lift up and remove the right speaker.
Brady Hildreth
Membre depuis le 11/04/19
361 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S1-G4, Henning Fall 2019 Membre de l'équipe IUPUI, Team S1-G4, Henning Fall 2019
IUPUI-HENNING-F19S1G4
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 18
Total : 654
