Aller au contenu principal
Samsung Series 9 NP900X4D-A03US WiFi Card Replacement
Ce dont vous avez besoin
  1. Samsung Series 9 NP900X4D-A03US WiFi Card Replacement, WiFi Card: étape 1, image 1 de 1
    • Use the screwdriver to remove the ten 2.5mm Phillips #00 screws.
    • Remove the back panel of the laptop.
  2. Samsung Series 9 NP900X4D-A03US WiFi Card Replacement: étape 2, image 1 de 1
    • Locate the WiFi card once you've removed the back panel.
  3. Samsung Series 9 NP900X4D-A03US WiFi Card Replacement: étape 3, image 1 de 1
    • Remove the two 2.5 mm Phillips #00 screws.
  4. Samsung Series 9 NP900X4D-A03US WiFi Card Replacement: étape 4, image 1 de 1
    • Remove the two wires connected to the WiFi card using a nylon spudger.
  5. Samsung Series 9 NP900X4D-A03US WiFi Card Replacement: étape 5, image 1 de 1
    • Gently lift up the WiFi card to remove it.
Aimee Young
Membre depuis le 04/22/19
293 Réputation
2 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G4, Cardinal Spring 2019 Membre de l'équipe UW Tacoma, Team S1-G4, Cardinal Spring 2019
UWT-CARDINAL-S19S1G4
3 membres
3 tutoriels rédigés
3 commentaires
Does Intel AC-7260 work in Samsung NP900X4D for faster WiFi Speed , The N-6235 is slow!
Ben - Réponse
It does. I just added the AC-7620 to my NP900X4C. And it works perfectly! Speed difference is huge. Went from 70 to 80 mbps to 250 mbsp on a 300 mbps connection. USB dongles didn't make much of a difference. It you have an older 900x give this a try.
AC-7620 WiFi card on Amazon
Heron - Réponse
Also if you do a clean install of Windows 10, the bluetooth driver doesn't install automatically. Here was the last version released by Intel.
Latest Intel Bluetooth Driver
Heron -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 21
Total : 1,073
