Aller au contenu principal
Samsung SmartCam HD Speaker Replacement
Ce dont vous avez besoin
  1. Samsung SmartCam HD Speaker Replacement, Speaker: étape 1, image 1 de 3 Samsung SmartCam HD Speaker Replacement, Speaker: étape 1, image 2 de 3 Samsung SmartCam HD Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Remove the mount.
    • Use the mount replacement guide if necessary to take the mount off.
  2. Samsung SmartCam HD Speaker Replacement: étape 2, image 1 de 2 Samsung SmartCam HD Speaker Replacement: étape 2, image 2 de 2
    • Unscrew the screw next to the mount holder.
  3. Samsung SmartCam HD Speaker Replacement: étape 3, image 1 de 3 Samsung SmartCam HD Speaker Replacement: étape 3, image 2 de 3 Samsung SmartCam HD Speaker Replacement: étape 3, image 3 de 3
    • At the bottom of the SmartCam there is a tab that you can stick a spudger r in.
    • Once the spudger is in, gently pry it open.
    • Work your way around the SmartCam with the spudger loosing 8 clips.
    • Buttons may fall out, but can be reinserted easily.
  4. Samsung SmartCam HD Speaker Replacement: étape 4, image 1 de 2 Samsung SmartCam HD Speaker Replacement: étape 4, image 2 de 2
    • Gently remover the cover.
    • Beware of the wires connected to the camera.
  5. Samsung SmartCam HD Speaker Replacement: étape 5, image 1 de 3 Samsung SmartCam HD Speaker Replacement: étape 5, image 2 de 3 Samsung SmartCam HD Speaker Replacement: étape 5, image 3 de 3
    • The speaker should be attached to the cover with red and black wires going to the main board.
    • Unscrew the two screws holding the speaker in place.
  6. Samsung SmartCam HD Speaker Replacement: étape 6, image 1 de 3 Samsung SmartCam HD Speaker Replacement: étape 6, image 2 de 3 Samsung SmartCam HD Speaker Replacement: étape 6, image 3 de 3
    • Gently take the speaker out of the cover.
    • Take out the red and black wires from a small plug-in on the main board.
2 autres ont terminé cette réparation.
Pranab Baidya
Membre depuis le 06/27/17
104 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team S1-G1, Liner Summer 2017 Membre de l'équipe UW Tacoma, Team S1-G1, Liner Summer 2017
UWT-LINER-SU17S1G1
4 membres
6 tutoriels rédigés
Un commentaire
You mind giving speaker part number. I have the Samsung camera with the smaller speaker. Any ideas
frank scalise - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 569
