Aller au contenu principal
Introduction
This guide will show you how to remove the back panel of your phone and replace the battery.
  1. Using your fingers, pry along the groove at the top of the phone.
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
  2. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  3. With your fingers, pry from the bottom of the battery to loosen it.
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
2 autre(s) ont terminé cette réparation.
Angelica Macrohon
Membre depuis le 16/10/2013
249 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-32, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 11-32, Amido Fall 2013
CPSU-AMIDO-F13S11G32
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 745
