Introduction
The rear camera is on the back of the phone and faces away from the screen. This is the highest quality camera on the phone and easiest to damage.
Ce dont vous avez besoin
Using your fingers, pry along the groove at the top of the phone.
Pull back on the rear casing until it comes free from the device.
The casing will make a cracking sound as it is removed.
Locate the red and white sim card located above the battery housing.
Remove the sim card by sliding it downwards from its slot with your fingers.
Gently pull the camera to the left while keeping it as close to the motherboard as possible.
The metal foil connector attached to the camera should slide out of the motherboard.
5 autres ont terminé cette réparation.
