Aller au contenu principal
Samsung Sway Rear Cover Replacement
Ce dont vous avez besoin
  1. Samsung Sway Rear Cover Replacement, Rear cover: étape 1, image 1 de 1
    • Turn over the phone and make sure the slider is closed.
  2. Samsung Sway Rear Cover Replacement: étape 2, image 1 de 2 Samsung Sway Rear Cover Replacement: étape 2, image 2 de 2
    • Using your thumb(s) slide the battery cover up to remove it.
  3. Samsung Sway Rear Cover Replacement: étape 3, image 1 de 2 Samsung Sway Rear Cover Replacement: étape 3, image 2 de 2
    • Using your finger, grasp the corner on either side of the battery and pull up.
  4. Samsung Sway Rear Cover Replacement: étape 4, image 1 de 1
    • Unscrew the four corner .4cm Phillips head screws and the two middle .3 cm Phillips head screws.
  5. Samsung Sway Rear Cover Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Gently insert a pair of tweezers under the Samsung logo on the bottom of the phone. Then unscrew the two .4 cm Phillips head screws underneath.
  6. Samsung Sway Rear Cover Replacement: étape 6, image 1 de 1
    • Gently insert the plastic opening tool into the seam where the battery was located. Work the opening tool around until the back cover comes off. Make sure to be careful of the side buttons that pop off.
Chris Rush
Membre depuis le 06/27/13
306 Réputation
3 tutoriels rédigés
Équipe
WRI115, Team 1-2, Ruszkiewicz Spring 2013 Membre de l'équipe WRI115, Team 1-2, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 283
