Aller au contenu principal
Samsung TFT Color YP-T7J Front Cover Button Replacement
Ce dont vous avez besoin
  1. Samsung TFT Color YP-T7J Front Cover Button Replacement, The Back Cover: étape 1, image 1 de 2 Samsung TFT Color YP-T7J Front Cover Button Replacement, The Back Cover: étape 1, image 2 de 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 2, image 1 de 2 Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 2, image 2 de 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 3, image 1 de 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 3, image 2 de 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 3, image 3 de 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Samsung TFT Color YP-T7J Front Cover Button Replacement, The Battery: étape 4, image 1 de 2 Samsung TFT Color YP-T7J Front Cover Button Replacement, The Battery: étape 4, image 2 de 2
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 5, image 1 de 2 Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 5, image 2 de 2
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
  6. Samsung TFT Color YP-T7J Front Cover Button Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: étape 6, image 1 de 3 Samsung TFT Color YP-T7J Front Cover Button Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: étape 6, image 2 de 3 Samsung TFT Color YP-T7J Front Cover Button Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: étape 6, image 3 de 3
    • Once the battery has been removed you can see the motherboard.
    • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
    • The USB connector can now be taken off of the device.
  7. Samsung TFT Color YP-T7J Front Cover Button Replacement, The Front Cover: étape 7, image 1 de 2 Samsung TFT Color YP-T7J Front Cover Button Replacement, The Front Cover: étape 7, image 2 de 2
    • Using the philips screwdriver, remove the two screws on the mother board.
  8. Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 8, image 1 de 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 8, image 2 de 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 8, image 3 de 3
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  9. Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 9, image 1 de 1
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  10. Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 10, image 1 de 2 Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 10, image 2 de 2
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
  11. Samsung TFT Color YP-T7J Front Cover Button Replacement, Front Cover Button: étape 11, image 1 de 2 Samsung TFT Color YP-T7J Front Cover Button Replacement, Front Cover Button: étape 11, image 2 de 2
    • Once the front cover is separated from the device, locate the four screws in the metal plate.
    • Using the small phillips screw driver, remove the four screws.
    • Remove the metal cover.
  12. Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 12, image 1 de 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 12, image 2 de 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: étape 12, image 3 de 3
    • Remove the rubber button pad.
Jason Farr
Membre depuis le 10/21/13
353 Réputation
3 tutoriels rédigés
Équipe
Clemson, Team 14-8, Benson Fall 2013 Membre de l'équipe Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 791
